Trans oil capacity on 2010 Street Glide
Finished 500 mile break in on the wife's SG. Changed fluids the manual states 1qt in tranny. After putting in one Qt the dipstick reads on full line when it suppose to be between the low and fill marks Is 1qt what evryones using? I put in a little over 3/4 but it did not even reach the halfway put thus I did the recommended 1Qt of Redline. I'm thinking the stuffs so thick it hasn't settled yet. Thanks
Dennis
Dennis
There is a dry fill (after you rebuild the tranny) and maintenance fill. I would go with the 3/4 qt to start with because it will have residual after draining, you just can't get it all out.
I did the same thing and overfilled. You can smell it on a hot day if it is overfilled. Had to get a suction gun from Advance Auto parts and suck some out. I keep mine on the lowest mark and when the engine oil temp is up to normal operating temp (around 230-240 degrees) it is right on the full mark.
Good luck, takes a couple of times to figure out the oil levels.
I also know the bike engine oil is only 3.5 qts cold, anything more than that it will blow it out when hot. The 3.5 level is also on the full mark hot.
jamesroadking
Oil Archive (no new posts)
10-06-2010 09:12 AM
