2012 Street Glide - Transmission Oil Question
Hello everyone,
I changed the transmission oil on my 2012 Street Glide. I added the recommended 32oz, rode it a few dozen miles and checked the oil (cold). The oil barely registers on the dip stick. Should I add more oil? Should I check it right after riding (hot)?
The bike was on the jiffy stand and the dip stick was resting on the threads (not screwed in).
Thanks!
Thanks!
Service manual says to check trans oil level with the bike on the jiffy stand and dipstick resting on the threads (do not screw in). OP, make sure the bike is hot and then check it. If it needs a little more just add some and then recheck. Sounds like you were doing it right.
The manual states to check the transmission oil level with the bike on the jiffy stand and the cap resting on the threads, not screwed in.
The engine oil level is to be checked with the cap screwed in.
It sucks when trying to be a wiseass backfires.
mikebaby
