Road King owners: Check your bars!
Old 08-30-2010, 06:15 PM
Roadking Cal's Avatar
Roadking Cal
Roadking Cal is offline
Default Road King owners: Check your bars!
OK, so here's the thing:
Last Friday, I was backing out of the driveway. I swung to the left, applied a little front brake, and everything went to hell.
Seems that when I stopped, there was just enough momentum to finish the process of destroying my handlebars. The left grip went down and forward, the throttle came back towards me. Needless to say, I completely lost control of the bike, but was able to slow its inevitable decent to the pavement. Since there was no rigidity in the bars anymore, getting it upright was a chore, to say the least. Fortunately, a neighbor came over, and we got it into the driveway.
So...I tear apart the nacelle and everything to find out what happened. The bars broke right between the risers. Not good. Thank God the wife & I weren't on the freeway!
When I went to the indy shop to get replacement bars, that's when I found out the bars I had in two pieces were not stock bars, as I had thought. I'm trying to figure out what they were, exactly, because the new stock bars SUCK! Too narrow, they look wimpy as hell, and I feel like I'm on a Vespa.
The indy wrench explained to me this theory:
When the original owner had the stock bars swapped out, the mechanic that did the work SHOULD have replaced the two stock clamps with a one-piece bar clamp. Seems that the wider, thicker bars can apply somewhat more torque, and since the risers are rubber-mounted, things can flex a bit. Enough that after 10 years, the bars gave out at the bottom, where the internal wires exit, and go into the nacelle.
So, RK owners, take an afternoon to check out what's under that handlebar clamp cover! You may be glad you did!
Old 08-30-2010, 06:45 PM
flyer91's Avatar
flyer91
flyer91 is offline
Thanks for the post!
Glad to see you found this out before it bit you hard.
I'm getting ready to put a set of 1.25" dia, mini apes on my RKC, and I will be sure to go to a one piece clamp now.
Once again ... a big thanks for the heads up!
Old 08-30-2010, 08:08 PM
jag1886's Avatar
jag1886
jag1886 is offline
That BLOW'S!!
Old 08-30-2010, 08:31 PM
elvisonsteroids's Avatar
elvisonsteroids
elvisonsteroids is offline
Did the indy suggest a brand of clamp? I'm running 16" apes and have alot of flex in the bushings and would love to go to a solid clamp but all i can find is the carlini for $200.
Thanks
Old 08-30-2010, 08:32 PM
yljkt's Avatar
yljkt
yljkt is offline
Its not enough of a pain in the *** to adjust them...now this?
Old 08-30-2010, 08:45 PM
IndyClassic's Avatar
IndyClassic
IndyClassic is offline
OP....glad to hear you are OK. HD sells the one piece, I think the unfinished version is less then $20 and the chrome one is about $30. Cheap insurance.
I got lucky when I did my 08 I bought the chrome because it was all they had in stock. Then found out MOCO changed to a one-piece in 08.
Hung over the workbench for 2+ years, kept thinking I should ebay it. This summer we bought the wife an 07 RKC and Saturday I put WO 518's on it. That nice chrome one-piece now sits under her nachelle!
Old 08-30-2010, 08:48 PM
petemac's Avatar
petemac
petemac is offline
Anybody have the part # for this one piece clamp?
Old 08-30-2010, 08:57 PM
IndyClassic
I think these are still good numbers.
Wild 1 recommends a one piece clamp part number 55918-08 that's almost $36. Harley had a 55917-08 for $21 but it's been superceded by the more expensive 55918-08 clamp. Still available, however, and also equal to the task is the old 56170-83T. It's only $16. (from a 2009 thread)
Old 08-30-2010, 09:04 PM
petemac's Avatar
petemac
petemac is offline
Thanks.
Old 08-30-2010, 09:17 PM
ddm502001's Avatar
ddm502001
ddm502001 is offline
I replaced mine with a one piece with my Wild 1 bars when I swapped out the OE bars.
Quick Reply: Road King owners: Check your bars!
