size of axle nut?
Old 09-03-2010, 02:14 PM
rlchristensenmd's Avatar
rlchristensenmd
rlchristensenmd is offline
Default size of axle nut?
I asked this question earlier on the tech forum and haven't had a reply. I need to remove the rear wheel on my 07 Road King. I don't have a wrench big enough to fit the axle bolt or dome nut. I will be going to the hardware store to buy a couple of sockets and would like to know if anyone can tell me the size for these. Thanks.
Old 09-03-2010, 02:33 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
36mm.
Carl
Old 09-03-2010, 03:02 PM
rlchristensenmd
Do I need two different sizes, one for the dome nut and a larger size for the axle bolt? It looked like the left side was slightly larger.
Old 09-03-2010, 03:08 PM
harry.b's Avatar
harry.b
harry.b is offline
Don't worry about the axel end. It won't move once you have some torque on the axle. Just hold it with a pair of channel locks or a crecent.
Old 09-03-2010, 03:20 PM
rlchristensenmd
Don't I need to turn the axle nut to adjust the belt tension?
Old 09-03-2010, 03:25 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,556 Likes on 659 Posts
Lightly tighten the 36mm nut, turn the other end to adjust belt deflection, then torque to 100 lbs. 1 1/8 will also work.
Old 09-03-2010, 03:27 PM
rlchristensenmd
Thank you.
Old 04-08-2011, 08:07 PM
camshaks's Avatar
camshaks
camshaks is offline
Default Whats the rear axle nut size on a 97 electraglide?
I read a few posts and went and bought a 36mm but it turned out to be waaaay to big. Looks more like a 1 inch. Biggest I have right now is a 3/4 and its a bit too small.
jed1069
04-06-2023 09:45 PM
P51Driver
2018+ Softail Models
07-02-2019 01:26 PM
tonyd2017
06-26-2019 09:06 PM
rlchristensenmd
Wheels/Tires
09-03-2010 08:50 AM
paul s
07-31-2009 09:28 PM
Quick Reply: size of axle nut?
