What cam upgrade is best to do in a 88 to 95 big bore
Old 10-08-2010, 01:16 PM
06GliderGuy's Avatar
06GliderGuy
06GliderGuy is offline
Default What cam upgrade is best to do in a 88 to 95 big bore
I have a 06 Street Glide wth a Woodys supercharger. Looking to do a big bore from the stock 88 inch to 95 inch. Right now the motor is stock other than the blower. I will be putting in forged pistonsand want to upgrade the cams whil I am in there. Any suggestions what cam might be a good match. Looking for a lot of low end grunt.
Old 10-08-2010, 01:23 PM
petemac's Avatar
petemac
petemac is offline
I went with the Andrews 26N cam when I did the hydraulic cam tensioner upgrade kit. A few months later I did the 95" and had the heads ported. Runs great!
Old 10-08-2010, 01:35 PM
LOOPNERS's Avatar
LOOPNERS
LOOPNERS is offline
Default cams
I am a big fan of S&S 510 gear drives and do any with the chain crap. Great power all across the band.
Old 10-08-2010, 02:09 PM
Mike's Avatar
Mike
Mike is offline
You're going to want a cam designed for blowers. Higher lift, narrow overlap, and long duration on the exhaust side. Call Woods or Andrews. A mild street cam will work, but you'd do better with a custom grind.
jammerx
2014-2023 Touring Models
31
12-11-2018 06:33 PM
yamaracer18
Exhaust System Topics
11
03-17-2012 07:56 AM
ga4boats
01-06-2009 11:57 PM
expolice
10-09-2008 08:06 AM
rickrides
05-25-2008 03:17 AM
Quick Reply: What cam upgrade is best to do in a 88 to 95 big bore
