Drilling pipes
Old Oct 2, 2006 | 12:00 PM
acadien's Avatar
acadien
Default Drilling pipes
Gents
Anyone drill holes in the left pipe I see this pipe is restricted.I want to get a bit more sound out of these pipes.Or is this a No No.
Roger.
Old Oct 2, 2006 | 12:13 PM
Akitakoi's Avatar
Akitakoi
Default RE: Drilling pipes
I have been thinking about doing some alterations.
I like the looks of the stock pipes I would just like to hear them a little more.
Of course you would need to retune using a sert or PCIII.
Old Oct 2, 2006 | 12:46 PM
Sreynold1's Avatar
Sreynold1
DANGER WILL ROBINSON...I asked this question before and got $hit hammered...be aware.
Old Oct 2, 2006 | 12:52 PM
Akitakoi's Avatar
Akitakoi
I just did a little searching, It's a NO, NO!
Old Oct 2, 2006 | 02:51 PM
bountyhunter's Avatar
bountyhunter
Get some beer & start drillin', just make sure the clamps are snugged up real tight first....start with a 1" bit on a hammer drill, keep goin' bigger til ya get the desired sound & performance....no need for a PCIII![sm=bangbang.gif]
Old Oct 2, 2006 | 02:57 PM
Mr Wonderful's Avatar
Mr Wonderful
Caution.........most guys that have drilled out the stock mufflers have not been happy with the sound.....and they've just boogered their stock mufflers. Wait! Listen for something you like and purchase those.......and keep your stockers for back-up just in case the local PD enforces the db law.
Old Oct 2, 2006 | 07:21 PM
Mick's Avatar
Mick
Well it's your bike and whatever you want to do is ok.
I've been thinking the same thing , but , there are lots of dresser mufflers on EBAY in the 30-50 bucks range.
At least if you wind up buggering them up , you didn't lose much.
I tried opening up the little holes in the end of both pipes to 3/8" and that wasn't much help.
Then the catalyst just "fell out of the right pipe" if you know what I mean.
After that , the sound is real close to what I want , but I sure would like to canibalize a pair just to see.
The majority of the exhaust is going to exit the right pipe anyway , stock , so the sound is going to be pretty smooth compared to true duals.
If you went a little at a time with a long drill , from both ends of the mufflers , you probably could come up with a happy spot along the way.
If you do come up with a combination that works for you , post your results.
What year is your EGS?
Luck
Mick
Old Oct 2, 2006 | 07:37 PM
gunrunner's Avatar
gunrunner
Been there done that. Doesnt sound much better, and both mufflers are the same and most of the exhaust comes out the right side not the left. So drilling it out will do little if anything at all.
Old Oct 3, 2006 | 07:11 AM
acadien's Avatar
acadien
Gents
After listening to these comments I think this might be a lost of time and I just found a set of Sampsoms for 250.00 so I might give these a try. Will I need to retune after doing this and will my motor run cooler thats the most important reason why I want to change my pipes. this is an 07 EGS Mick.
Roger.
Old Oct 3, 2006 | 07:29 AM
vabiker07's Avatar
vabiker07
Got a set of Screaming Eagle slip ons ( degutted) for sale if anyone is interested
