"Installing '10 RG fairing brackets, vented lowers, and CVO SG speaker boxes"
Attached is the parts list need for the HD vented lowers with the 2011 speaker pods. The list includes the mounting hardware also. You will need to get 6 screws to attach the pods to the lower fairings. Keep in mind that these are primed parts and you will need to assemble them. This list does NOT include speakers or speaker grills. The prices shown are from one of the well known on-line dealers. Your prices may very.
HD's new "Boom Audio Custom Touring System," p/n 76000209, includes the CVO speaker boxes. The installation instructions and parts list are in this pdf file:
http://www.harley-davidson.com/en_US...ts/-J05408.pdf
It's worth looking at the instructions because they describe how to: (1) install the speaker boxes ("housings") in the vented lowers; (2) drill the hole for the speaker wires into the boxes/housings; and, (3) includes a parts list for the wiring used in that kit (which is slightly different from how I did my installation).
FWIW, the instructions say to reuse the three screws that held the glove box in the vented lower when installing the speaker box/housing; that's also how I did mine.
Interestingly, the kit does not provide p/n's for the boxes/housings; but, the p/n's supplied by the OP are still valid so presumably the speaker boxes/housings and still be ordered separately; i.e., HD hasn't stopped selling them apart from this kit.
I haven't read closely the information in the instructions regarding drilling the holes for the speaker wires--see page 6 and Figure 4. But it's helpful that HD has supplied the information for those DIY'ers who are assembling their own audio "kits" so to speak--no point ruining lowers or the installation by drilling a bad hole.
Good luck with your project.
Carl
Carl
I don't recall the actual speaker manufacture. I measured the inside area of the pod where the speaker grill fits and then hunted e-bay for that size. I ended up using the black ones.
I am in the process of trying to install some Mutazu lower vented fairings, with speaker boxes.
Everything was great until I discovered that the upper fairing sast too low.
I have ordered some '10 engine guard brackets.
Question: will i also have to change the center main bracket?
How about headlight aiming.
Thanks
Thanks
Thanks
Thanks
