Anyone using Nitrogen in the tires?
I recently did some work with a National Tyre fitting company here in the UK and asked the relevance of using Nitrogen.
1. As Nitrogen molecules are larger than Oxygen, they do not leak out as naturally from the tyre - In other words they (the tyres) remain inflated and at correct pressure longer. This answered my query regarding how to check and inflate at home, the answer is that inflation top us should be required less frequently, and usually the tyre fitting service include free top ups (at least the company I was working with).
2. The Nitrogen works with a wider temperature range, so the tyre pressure fluctuates less across differing climatic conditions, it's also why Nitrogen is used in race tyres to ensure a fixed pressure.
Correct pressure ensure best performance, reduces low pressure tyre wear and can improve fuel economy.
It all seems to make sense, just need to get round to having them filled.
