Just Installed HD LED Headlamp and Driving Lights
Just finished installing HD's LED headlamps and Driving Lights on my 2010 Ultra.. Dealer said Headlamp was just 'Plug and Play" well not really.. You have to REPLACE the stock mounting bracket with the bracket supplied with the the new lamp... The retaining ring gets re-installed. but HD forgot to tap one of the holes so I could not secure the lamp until I tapped it..(guess they never checked). Frustrating but worked out OK... Now that is dark out.. Bike looks like a Freight Train coming down the road, cant wait for the Air horn, so it sounds like one too.... pics to follow soon..
Here's a short video.....hard to tell in the video I guess but they are WAAAAY brighter!
http://www.youtube.com/watch?v=308Ima6XiLs
I too did the LED upgrade recently. My problem was the new mounting ring holes that you use to screw it to the bat wing, I had to open them up some because the screws wouldn't fit, they needed to be wider apart. The hole pattern was too small in diameter. But after that it was a no brainer. And Gawd how I love it. Question, does anyone ever use the high beam? I don't see much difference.
The reason I ask is my riding buddy put a new high intesity light package on his bike, and I can tell NO difference in the daytime.
The reason I want it is for visability in daylight hours.
Also does your system strobe? His front & rear does, but it's hardly visable from the rear.
I would appreciate any feed back.
