bypassing clutch start switch??
Old 04-04-2011, 02:40 PM
onebad2's Avatar
onebad2
onebad2 is offline
Default bypassing clutch start switch??
My buddy just bought a 06 electraglide police bike and wants to by pass the switch ythat makes it so he has to pull clutch to start it?? and thoughts Thanks
Old 04-04-2011, 02:44 PM
slothy's Avatar
slothy
slothy is offline
just solder the 2 wires together that goto the switch - so bike will think clutch lever is in all the time. (at least works on the metrics)
Old 04-04-2011, 04:29 PM
Cheech2010FLHTK's Avatar
Cheech2010FLHTK
Cheech2010FLHTK is offline
and just hope he never hits the start with the bike in gear once he jumps the clutch switch
Old 04-04-2011, 04:49 PM
davessworks's Avatar
davessworks
davessworks is offline
In case it applies to anyone else reading this thread, don't do this if you are running a bike with cruise control.
Old 04-04-2011, 04:58 PM
18BKLR's Avatar
18BKLR
18BKLR is offline
Why?
When I put my new controls on mine I just removed the switch. Cruise still works the same. Cancels upon squeeze of the clutch. That's the way it is supposed to work
Old 04-04-2011, 05:03 PM
davessworks
Originally Posted by 18BKLR
Why?
Good point - cruise will still work, it just won't cancel the way it's supposed to.
Old 04-04-2011, 05:11 PM
18BKLR's Avatar
18BKLR
18BKLR is offline
On an 06 you are correct. Mine is an 08 so cruise is done through the compuuter. Sensors do it all. When you pull the clutch the cruise turns off. Changes the speed and load for the motor so shuts her down. Thats the way I understand it.
Old 04-04-2011, 08:07 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 48,291 Likes on 18,742 Posts
Not a good idea .... one brain fart could lead to him and his machine layin' "sunny side down" in the parkin' lot. The old scooters were this way and many a night we'd see someone pushin' the button before thinkin' .... and before ya knew it .... flop!
Old 04-04-2011, 08:53 PM
onebad2's Avatar
onebad2
onebad2 is offline
He has lots of miles on a few different harleys and none had that setup, He will be safer without it im sure!. thanks for all the info. will fix it up this weekend.,
Old 04-04-2011, 10:28 PM
skratch's Avatar
skratch
skratch is offline
Received 4,237 Likes on 2,473 Posts
how? just because he's never had that setup before doesn't mean he's better off without it. i could understand wanting to bypass it if it were something like the metric kickstand deal. but, with this system, the only time that you would even notice it, is if you were doing something wrong in the first place. you can start your bike in neutral like before, only have to pull the clutch in if you are in gear.....
Quick Reply: bypassing clutch start switch??
