Rear Brake Light Switch
Old May 8, 2011 | 06:15 AM
Artlee's Avatar
Artlee
Mine is going too. I have to press the pedal harder and harder to get it to come on.
Funny, I was just researching this topic yesterday on this site and found this posting, which has some good info.
https://www.hdforums.com/forum/sport...t-again-2.html
Old May 8, 2011 | 07:28 AM
TI06's Avatar
TI06
I just had mine replaced too. It was staying on. This caused an ABS fault and cruise control also wouldn't work. My check engine light stayed on also. I thought I had some big problems but it was all tied in to the brake switch. New switch and all the other stuff was fine.
Old May 8, 2011 | 07:47 AM
Lass7711's Avatar
Lass7711
When mine went out, the first sign was constant static on the radio. I had just got back from a ride. I assumed I had a radio problem. I started searching for antenna and ground problems. After a short while, the static only happened when I used the rear brake pedal and I figured out the brake light didn't work when I used the pedal. That clue lead me to the rear brake switch. Before I could get to the dealer, I found brake fluid under the bike. It was replaced under warranty.
Old May 16, 2011 | 04:08 PM
themensh's Avatar
themensh
2009 Ultra.
My rear brakes failed yesterday 150 miles from home....melted switch.
Taking it to dealer tomorrow.
Old Aug 16, 2018 | 11:33 AM
trigger1911's Avatar
trigger1911
Easy fix and no need to bleed the brakes. Just depress the brake pedal when the switch is lightly inserted to let the air out. autozone Duralast #RB401 with lifetime warranty for $13.49!
Old Aug 16, 2018 | 02:44 PM
fordhd2005's Avatar
fordhd2005
Nice! Where were you 7 years ago?!! lol
Old Aug 16, 2018 | 02:47 PM
trigger1911
Smile
Probably drunk! This was the first thread that came up on a search so maybe it will help someone out in the future. Now stop bothering me so I can get to the bar! Geez!
Old Aug 16, 2018 | 03:28 PM
Mike flhp's Avatar
Mike flhp
There's a recall on some years/models. My recall replacement failed as well, go figure.
hdmc01
Oct 3, 2022 04:43 PM
lakedrum03
Apr 17, 2017 05:05 PM
ORradtech
Aug 27, 2016 09:39 PM
kzoo
Jul 19, 2011 08:56 AM
dert
Sep 12, 2005 11:06 AM
