Adjustable Pushrods ??
Old Jun 28, 2011 | 01:54 PM
Glyder's Avatar
Glyder
Default Adjustable Pushrods ??
FuelMotos use the stock pushrod tube....for those of you that have used them were they any harder to install then the types that come with new pushrod tubes also such as the Screaming Eagle or S&S kind. My dealer wanted to charge more labor to use the FuelMoto pushrods because he said they were harder to put in then the others that come with different tubes.
Old Jun 28, 2011 | 02:20 PM
Sam2010's Avatar
Sam2010
IMO if you use them a lot probably not that big a deal. But I found it to be kind of tight the first time the second time was much easier. Dont ask why I did it two times. LOL However I already bought new push rod tubes so when I eventually do the big bore kit I am defiantly using them.
Old Jun 28, 2011 | 04:44 PM
davewear's Avatar
davewear
i've only installed pushrods once so i don't have much to compare to but putting fuelmoto's pushrods in my stock tubes was pretty damn easy and i can't see how different tubes would change anything.....
Old Jun 28, 2011 | 05:25 PM
mrmud4x4's Avatar
mrmud4x4
Did fuelmoto give you that tube tool that holds the tube up? If so...did that help out?
I've been thinking of using theirs also.
Thanks,
BTW: the other adjustable pushrods come with tubes that are shorter I think, to give easier access to the rod adjustment nuts.
Old Jun 28, 2011 | 06:30 PM
davewear's Avatar
davewear
Yup they came with the tube holder upper tool.. Access to the adjustment nuts was no prob
Old Jun 29, 2011 | 08:48 AM
mrmud4x4's Avatar
mrmud4x4
cool...thanks!
Old Jun 29, 2011 | 09:17 AM
Sam2010's Avatar
Sam2010
What it changes is dont need the damn easy tool holder upper in your way.
Old Jun 29, 2011 | 11:37 AM
TNCarters's Avatar
TNCarters
Most have probably seen it but J&P has posted a nice YouTube video of changing out and adjusting S&S pushrods with complete cam change video. Interesting to watch even if your not using their pushrods or cams. Thought it interesting they used a paperclip and rubber band to hold tube up. Make it look easy but they skip all the prep and wrap up tasks.
Old Jun 29, 2011 | 12:37 PM
rg_dave's Avatar
rg_dave
That's what tons of people do.
speakerfritz
Apr 25, 2012 01:10 AM
jarhead45
Aug 28, 2011 10:43 AM
Glyder
Jul 6, 2011 10:36 PM
CndUltra95
Jan 14, 2009 09:22 AM
Road King Kid
Exhaust System Topics
11
Jan 7, 2008 06:08 PM
