Fairing removal nightmare
I had bought a new windshield, and on replacing the bolts, one threaded insert began to slip. It's been too hot to ride through the day, in Illinois, lately. So I thought I'd take off the fairing and repair the insert. I went to my local HD dealer and bought 2 of the repair inserts and some Boom Audio speakers. (While the fairing was off, I thought I would upgrade speakers as well. This was the easy part of the day) The repair insert is a new threaded insert that is split on top. You put the bolt in, and twist it in where the factory insert has been removed. The split portion breaks off and then you back out the bolt. Easy right ? (The portion that breaks off isn't square.) So when I tried to put the fairing back on, The insert on the other side broke loose ( this was the last bolt of the job
