I replaced one last night...pissed me off. I had issues out of the box with the grommets pulling out. The replacements do work good. Pissed I had to pay for them too! Warranty my ***.
I misquoted the price on the inserts. They're 1.70 each. Sorry about that. Do you mean pretreating each insert with epoxy ? Good question. Should be done on manufacture shouldn't it ?
[quote=ral819;8563077]I misquoted the price on the inserts. They're 1.70 each. Sorry about that. Do you mean pretreating each insert with epoxy ? Good question. Should be done on manufacture shouldn't it ?[/quote
It should but since it's to late I'll do it next time I open her up
The easy thing to do is to stick the insert on the end of a soldering iron. After a minute to heat up, just slowly insert the insert back in the hole. let the plastic start to bubble then while holding the insert in place with a screwdriver slide the iron off the insert and let cool.
Anybody have the part # handy? My original insert came out then I used Gorilla Glue and when I put the bolt back in darn bolt broke and 1/2 the insert. Guess its drill time unless you guys have a better solution.
