Road King rear signal bar options
#51
Hi Buckinfitch,
very nice look! If it's allowed, i will copy this!
Sorry, my english is not the best - so i cannot understand all the words on the Kuryakin webpage.
Question:
You have installed the "Bullet Light Rear Turn Signal Bar" with the number 2098 - right?
Do i need something else? What does this mean in the info text: "Bullet Styler L.E.D. inserts sold separately." --> what's this?
Please, can you / somebody help me, that i can order everything what i need for a functioning and complete Kuryakin Signal Bar?!
Thanks and greetings from Austria (without Kangaroos )
Martin
Question:
Martin
after positioning bracket just right I held up and placed the LED frame up to it(you will need to drill the two top holes of the LED frame) to bolt onto the bracket now bolted onto fender, I held the two together with small C clamps while drilling, (also will need to notch out a small square on your plate for the LED wires(easily done with a good pair of wire cutters) and covered by the frame, I think the location for the cut was on the instructions, but who reads them?
law states you plate hs to be illuminated, here is the frame I used, very nice chrome/illumination
http://www.radiantz.com/index1.html?c17.html&1
I also replaced my red lens with a (no plate window) lens, you can prolly just use transparent red tape or paint?
http://cgi.ebay.com/ebaymotors/KURYA...item1c1bd03771
here's what I used to cover the holes in the fender after removing the plate bracket.
http://cgi.ebay.com/ebaymotors/Harle...item25665a316c
a pretty cheap mod for under $100.
#52
Hi Buckinfitch,
thanks, thanks, thanks for your advice!
Please look and read a second time my question --> one thing is still open.
Do i need something else? What does this mean in the info text at the Kuryakin webpage: "Bullet Styler L.E.D. inserts sold separately." --> what's this?
Thanks
Martin
Thanks
Martin
#53
it does come with smaller LEDs underneath in the middle of the bar to illuminate your plate.
http://www.kuryakyn.com/Products/665...urn-Signal-Bar
#55
#57
electra_boogaloo
04-16-2017 09:18 PM
