HELP almost no rear brake!
I have a 2008 Road Glide with Brembo ABS 9500 miles. Left this morning to go for a ride and at the first stop rear brake pedal went all the way down and just barley slowed the bike. I used a lot of front brake and turned around and went back home and parked it back in the garage. I have not had a chance to take a look yet but what do you guys think could be the problem? It was fine last week when I went for a ride and I have not done anything to the bike since. Could the pads just be worn and need to be replaced or could the fluid be low? I would think if it were the pads they would start grinding or scrubing like a car does. Again I have not even taken the bag off to take a look yet.
Thanks in adance for any help.
You should be using mostly the front brake anyway. The front brake does 85-90% of the work. The likely hood of locking up the rear in a panic/emergency stop are increased if you use the rear only most of the time. Once underway I almost never use the rear brake. Only in hard stopping situations will I apply the rear brake while at speed. Not slamming just trying to educate. Proper braking is very important.
Neil
RDMC
Neil
RDMC
Neil
RDMC
Neil
RDMC
not slamming, just trying to educate. proper braking is very important.
Thanks guys, I will check the fluid. Couple of questions on that, I have not had any leaking that I have seen on the garage floor? When I check the rear master cyclinder fluid does the bike need to be level, on a jack or lift? Also should I go get some HD brake fluid or will another brand work just as well to top it off?
Neil
RDMC
Neil
RDMC
If low fluid is your problem then you wont be able to see any fluid at all.
You may not see a leak on the floor in the garage as it would only leak a serious amount when you are applying the brake.
And personally unlike neil I dont give a fark about how you stop your bike -front brake, rear brake or dragging your feet. Whatever works for you.
Neil
RDMC
Neil
RDMC
