Tried almost everything, bike won't start. Need suggestions.
Take your battery to Sears / Auto Zone have them check it, with a "Load Tester"
Check Ignition Coil: $ 20 - $ 50
http://www.ehow.com/how_5978741_chec...tion-coil.html
http://www.sears.com/search=ohm%20meter
How Old is your gas ? http://www.goldeagle.com/brands/stabil/products.aspx
Oil - and full
Replace Fuel Filter - that is cheap insurance
Oil - and full
I would take off the air cleaner and squirt a little (just a little) gas in the throttle body. You can also use starter fluid (better). if It tries to start it would appear it has to do with something in the fuel system. Also as suggested take out one plug and strip some wire then wrap it around the threads tape it on so it won't fall off (make sure you don't cover up the part that fires) take the other striped end and attach to a bare ground on the bike. The reason for this is if you just hold the plug with your hand as you are cranking it and you accidentally loose your ground, you might damage your computer, not 100% on that but why take a chance. Crank it and look for spark.
They also make a little tool for checking for spark some you just lay on the spark plug wire and it lights up as you crank it, another tester you remove the plug wire, stick plug wire on one end of tester and the other end of tester goes on the plug. I think Harbor freight has them.
Lastly if if you have fire, and it didn't fire with you spray starter fluid in it, pull the plugs and spray a little right in the spark plug hole, replace plugs and turn over.
Make sure your battery has a charger on it or charge it overnight. If it's low it may have enough juice to turn it over but not enough to operate the injection system too.
Hope this helps.
Hope this helps.
Seriously:
Get a pair of insulated pliers and hold the other end to anything that is grounded. If it is getting fire, you should see and arc over the plug gap.
