XIED (FL-VIED-10) Not Compatible With New FuelPak LCD 61019
Ultra simplified version:
Closed loop is less than half throttle under 4K rpm (i believe). Closed loop uses the O2 sensors to monitor engine and adjust air fuel mix. This is where you spend most of your time riding, and where Xied's can help you.
Open loop is under heavy throttle or at higher rpm. The O2 sensors are not used by the ECM in open loop. The ECM reverts to it's stored "maps" to adjust Air/fuel, timing etc. Open loop is where Factory downloads and Fuel Pak can help you.
Apparently the OP is saying the newest FuelPak uses maps at every RPM/engine load and by passes the O2 sensors all the time. Under those circumstances the Xied's can't affect the engine.
Thank you very much for the "KISS method" You made it very easy to understand and I very much appreciate your help!
Some days I am soooo sloooooooooow. lol
The PC V or the new Fuel Pak wont wort with XEIDs because they bypass the O2 Sensors and if you left them connected they would be fighting the device for control in closed loop.
Go with a Power Vision, Sert, TTS and you can keep the sensors intact to have the benefits of the closed loop and still have performance because these tuners make adjustments to both the open and closed loops by reseting all ECM parameters , not tricking the ecm into adding extra fuel or less fuel.
Maybe Vance & Hines or Nightrider can provide some definitive guidance. You can view the Fuelpak #61019 directions on the V & H website. Nothing is said about disconnecting O2 sensors with this new Fuelpak for 2011 models. Nothing on the Nightrider site indicating any incompatibility using their FL-ViED-10's with the new Fuelpak. Although my bike is running fine with both I'd like to know if the FL-ViED-10's are being defeated by the new Fuelpak!
stock bike starts and warms up and voltage comes out of the O2 sensors until the bike warms up and then a changed voltage gets sent from the O2 sensor. As long as the ECM considers the o2 sensor functional it runs in closed loop.
open loop is where the ECM thinks the o2 sensor has failed. In a failed O2 sensor senerio, the ECM will used the last successful O2 sensor transmitted values.
Now, enter passive devices like XIED's. They use a resistor pair to drop the voltage. Once the voltage drops to the point where the ECM thinks the O2 sensor failed, ECM runs open loop.
Now, the last remembered voltage transmission from the O2 sensor was during bike warm up in which he fuel mixture was rich.
