oil pressure
Old 09-11-2011 | 01:46 PM
butch63255's Avatar
butch63255
Default oil pressure
hey guys, i have an 05 electra glide classic, i start the bike and have oil light and zero oil pressure, (just started doing this and its not knocking that i can tell) then it will jump to 60 then back to zero with oil light then to 32ish back to zero back to 60 etc....when it went up i hopped on for a ride around the block and it didnt seem to make any differance still went up and down? bad pump? maybe a sending unit of some sort?guage? any suggestions please
Old 09-11-2011 | 02:08 PM
AlanStansbery's Avatar
AlanStansbery
If it was me, I wouldn't run it again until it's checked out by a good mechanic. Since the light and gauge seem to agree, I wouldn't think it's as simple as one or the other of them being bad.
Alan
Old 09-11-2011 | 02:52 PM
1flhtk4me's Avatar
1flhtk4me
How many miles on the bike?
First thing to check are the cam chain tensioners.These will wear and break which lead to oil pump failure.
Old 09-11-2011 | 02:59 PM
Stiggy's Avatar
Stiggy
If the lifters haven't collapsed, ( clacking,) you've probably got a sending unit problem which effects both the guage and the light.
Old 09-11-2011 | 03:00 PM
butch63255's Avatar
butch63255
thanks for the advice...it has 32000 miles on it.....any idea what i might be looking at for repairs? new pump? tensioners?
Old 09-11-2011 | 03:03 PM
butch63255's Avatar
butch63255
engine didnt sound any differant,seems to have the same noises it always had...regarding lifter clacking we talking loud clicking/ticking or might it not be so noticable change in sound?
Old 09-11-2011 | 03:26 PM
1flhtk4me's Avatar
1flhtk4me
I had a couple lifters go bad on my '06 TC.
There was a bad rattle sound on acceleration and decel.
With 32K on the motor I would suggest checking the tensioners if you have not done so.
If the tensioners are shot then the pump could be scored.
You would need a new pump,tensioners and might as well replace the cam bearings.There is also a replacement hyd. tensioner kit that replaces the stock type tensioners.
Old 09-11-2011 | 04:34 PM
Sandy Mike's Avatar
Sandy Mike
Same thing happened to me last fall on my '05 when it had just over 50,000 km (30,000 miles) on it. Dealer replaced the oil pump as well as the cams and bearings that got screwed because of the oil pressure loss.
No warning before it started doing it other than the pressure seemed a bit low on the guage at idle.
I would get it checked for a bad oil pump.
BTW, cost to me for the repair was ---- $50.00. The ESP paid off.
Old 09-11-2011 | 05:12 PM
butch63255's Avatar
butch63255
thanks for the info and advice from all...have a great day
Old 09-11-2011 | 05:49 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
jumpimg up and down makes me think u got pieces off cam chain tentioner trying to move through the oil system, or a bad sending unit.
Quick Reply: oil pressure
