Converting 08' and up TBW to standard Throttle Cable???
Hello everyone,
I'm checking to see if there is a brand or company out there that makes a kit that converts 08' and up Harley's that have Throttle by wire back to standard throttle cable (idle cable as well, if applicable)
Any help would be greatly appreciated.
-Sam
-Sam
As one with 39,000 miles on my '08 TBW bike, I can't understand why anyone would want to go back to a throttle cable. I've never had a problem with TBW but I have had broken throttle cables over the years.
If you want a newer bike, you should accept the newer technology that goes with it.
Gentleman,
Thank you for your input. Apparently my computer didn't post the original thread I started but then it showed up after a "reboot".. Regardless, thank you for all the responses, I truly appreciate your time.
-Sam
-Sam
Mine's in the shop for the 4th time getting repaired.
I like it when it's working. There's no cables showing and gives the handlebars a cleaner look. The throttle response time is not a problem for me-the down time is. I guess some work better than others.
I would guess that there's been a lot more TBW problems than throttle cable problems.
