Starter Clutch vs heat
the starter clutch?--- you mean the bendix on the starter shaft? which when rotated extends to contact the ring gear on clutch basket
or do you mean the starter motor or solenoid-?
both the electrical components are affected by heat,
heat causes resistance in electrical circuits, coils, switches etc. and that resistance creates more heat...it's like a snake eating it's tail.
keep connections clean and tight, if you have solenoid problems, they are easily rebuilt, starters too are easily serviced.
( most solenoid problems are caused by low battery- instead of the solenoid contact disc getting a good pull onto the contacts, a weak pull causes arcing, pitting and carbon on the disc and contacts)
as long as the coils in the motor are not burned up, the starter will last a long time....decades
as for pipe proximity, that could be a factor, but H-D starters are close to the rear cylinder, on top of the tranny and oil tank and right by the exhaust...until recently the rear header was the "Y" pipe used for decades, the pipe passed within inches of the starter--- on my 88 FXRP the header pipe was attached to a bracket on the primary RIGHT ON TOP of the bendix
mike
mike
The starter clutch is going bad, and was said that the extra heat coming off the pipes that cross over the top of the starter is wearing out the starter clutch, for the second time. I have other friends with the same pipes, touring bikes, and never have had this issue. I wish I could do the repairs myself but have no place to do it, sucks.
