These exhaust pipes where on when I purchased this 01 FLHTC and I looked all over them to find a name or part number but no luck. I took one of the turn-down tips off and some of the baffling extends beyond the muffler end so you need caps. I want to get some other type of end caps.
If anyone can ID these or where I can get end caps. I would be greatful. The mufflers are 3.5" and the end caps slip over the mufflers and has three screws holding them on.
Thanks for your help, however, I found the name on the bottom under some bluing. They are Kerker Slip ons. I think they are affilated with Supertrap. Is there anyway to get the bluing off?
At one time there was something called Blue Away use it back in the 70's, I was told to pull the muffler clean with Blue Away, then spray some white VHT header paint inside to coat area that was turning blue from heat. It worked then, may not with engines running so hot now days.
