SG MIRROR
HI GUYS, Anyone tried to installed a sg side mirror(front fairing mounted)) to a 07 ultra??
i really diggin the fairing mounted side mirror. and finally what 'SERT' stands for??
ride safe
ride safe
Before you commit to the fairing mount mirrors sit on a SG or similarly equipped bike a make sure you can see enough in them to be useful. I added handlebar mirrors to my SG because for me all I could see in the original mirrors was my hands and forearms.
FBL
FBL
I like the fairing mounted mirrors much better. Cleaner look and very usable. Easily installed with simple tools.
JL
JL
yep....easy...get after it, you'll love em....mine are great....
a SERT is a tune, it comes with a CD of maps and instructions...and a dongle that once used will be specific to your bike from then on....SERT stands for Screamin Eagle Race Tuner, get a competent dyno man to tweak it for you...keep in mind most HD dealers do not have a competent tuner and will slap a map on you for 400 bucks, then tell you its as good as it gets...i run a SERT as do many here, there are 220 parameters for adjustment, more than PCIII...the PCIII is also a good system which has a piggyback ecm, you will find more dyno guys proficient with them than SERT
I put the mirrors on my Ultra. Took about a day to get used to them because the angle is slightly different, but now I feel like I have a much better field of vision.
The install took all of about 30 minutes.
ORIGINAL: fatboylust
FBL
FBL
