Air Ride + Lowering kit in rear?!?!
Has anyone done this?? Not looking to ride around extremely low, just wondering if anyone has attempted doing this on a touring bike to get extra low while parked?
Let me know if anyone has given this a shot or if I deserve a
This will be on my 04' EG with a baddad rear fender/stretched bags...
Lowering kit brackets put the shocks at a different angle I wouldnt want to put that much stress on an air ride shock because it could be hard on the seals and cause an early failure. My dad has lowering kit brackets, they were on his bike for two weeks, now they are on the top of his toolbox. Just my .02 I have legends air ride on my road glide and it goes plenty low for me when I park.
you can do it.
be aware that there is wiring inside the rear fender that the tire likes to eat.
replacing the stock wiring with "flat 4" wiring like on a trailer wiring kit, you can use silicone to adhere the wiring to the inner side of the fender.
remove any bolt ends sticking into that area, like seat mount
chances are if you do that, you'll be restoring some height after a week.
mike
mike
It would be helpful if ChoptXLC told us what brands of kit he has in mind.
I have custom air ride + la choppers lowering kit
I have a custom air ride on my 03 RKC from a local shop that makes kits called xotic customs in Lincoln Nebraska. I also recently installed an LA Choppers lowering kit and the goal I was trying to get to was (because I'm short legged) a ride height that is just enough so I can be flat footed but also not feel like I'm riding on metal. The lowering blocks allow my air ride to fill up with enough air now to be very comfortable at the right ride height. (It also handles better because lower center of gravity)
My question is how can I put in a safety measure (because I don't want to eat gravel at 80 mph) to stop the socks from going too low so my tire doesn't dig dig my fender? Would a limiter switch connected to my dump valve work? Are there frame blocks I could buy or make that could be a failsafe? Any ideas or suggestions would be helpful. As long as they aren't to take the kit or air off. My air has been good for 3 years so far, no issues or leaks at all. But I want to always make sure I make it home to my family.
thanks for any help
thanks for any help
