Primary Bearing bad ??
"identified it within 5 seconds of me starting the bike"
What is the sound like ? I ask cause somthin going on inside my primary..
https://www.hdforums.com/forum/touri...failure-2.html
Originally Posted by clarkchriston
Well I just dropped off my Out of Warranty 2008 Road King Classic with 11,000 miles the off at the dealer to verify that my inner primary bearing is bad. Both the service manager and lead tech identified it within 5 seconds of me starting the bike. Its being taken apart to confirm there is no other problem, then it's wait and see what Harley Tech Support says on if they will authorize the work. I spoke with Harley Customer Service and got a reference number for my dealer to call once they know for sure the extent of the issue. Hopefully they can convince Harley to stand behind their product
Here's Bakers PART#:http://www.bakerdrivetrain.com/drive...htorqueBearing
Here's Napa's #'s: bearing #6205-2zj Seal#: 25x52x7tc
As for the noise its like shaking a can of small ball bearings in oil. I described it in the thread you referenced.
Mine went out at about the same time while I was in the mountains of NC. The dealership tore it down and told me it was in the transmission and I would need to wait for the parts to come in. I rode it back to Florida with it making all sorts of noises and my Indy had it figured out in about 5 seconds...He could not believe the dealership took it apart past the clutch basket and was either trying to rip me off or was totally incompetent.
I now have 39,000 on it and also had to replace the Compensator.
Great Info. Thanks
Bearing was shot and rear seal on the bearing was leaking ....
See Pictures - do I need to replace the shaft race or just a good 100grit sand paper the roughness out ??
The sound was: In Netural at idle, sounded like a air leak, directly coming from the primary area, when I pulled clutch, shifted gear, it went away....
You have to replace both the inner race and outer bearing to keep with OEM and you need a special puller OR take a dremmel and cut the inner race off and get a one piece bearing and press it into the inner primary.
Race puller #620060 $133.50
http://www.georges-garage.com/trans_06_up.htm
Thanks
