Exhaust advice needed
Old 01-30-2012, 06:26 PM
k9t8m's Avatar
k9t8m
k9t8m is offline
Default Exhaust advice needed
I am looking to change the exhaust on my 07 FLHTC to a bub 7 setup. My question is, should I go with true duals with crossover, or just slip ons? The only thing done to the bike is a stage 1 kit. I am worried with the larger diameter headpipes i will lose back preassure and in turn lose a lot of low end torque.
Does anyone have any advice that can guide me a little?
Thanks!
Old 01-30-2012, 06:45 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Why are you considering larger diameter headpipes?
Old 01-30-2012, 07:50 PM
k9t8m's Avatar
k9t8m
k9t8m is offline
because I can buy this:
http://www.ebay.com/itm/Bub-Harley-7...sories&vxp=mtr
For the same or less as bub 7 slip ons.
Old 01-30-2012, 08:01 PM
Clayslayer's Avatar
Clayslayer
Clayslayer is offline
Depends on what you're going for. If you just want the sound go for the slipons put em on, and call it a day.
The Bub headpipe will flow better than your stock pipes but will also need a set of mufflers bolted to them. If your engine is otherwise stock, no cam, etc, there will be some power gain but don't expect a night and day difference. You might pick up somewhere around 5hp give or take.
To answer you original question: The bike will be just fine with the Bub header. It'll run and sound great. Just remember a good header is useless without a good set of mufflers attached to it.
Old 01-30-2012, 08:04 PM
69cj's Avatar
69cj
69cj is offline
I just went with slip-ons on my 07 rk and am perfectly satisfied.
Old 01-30-2012, 08:09 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Thats nice you can get a good deal, but its not very well suited to your application at stock 96" displacement. Must be a reason Bub doesn't make those anymore, just a thought.
Old 01-30-2012, 08:43 PM
k9t8m's Avatar
k9t8m
k9t8m is offline
I was kind of thinking the same thing, but thought someone would know better than me.
CookUltraClassic
02-13-2022 05:18 PM
Dyflam
01-31-2020 08:21 AM
seamonkey
03-27-2015 07:11 PM
BamaVan
08-09-2010 07:29 PM
hoz88
11-28-2007 11:32 PM
Quick Reply: Exhaust advice needed
