front brake lines 08 flhx abs
Old 02-02-2012, 10:13 AM
joee's Avatar
joee
joee is offline
Question front brake lines 08 flhx abs
looking for info on changing front brake lines i want to but braded line on it looks like the line from the handelbars is one line and the one from the block they go in to two other lines beside the tank the question i have is were they meet under the tank it looks like black heat srink on the couplings if they are couplings under the heat srink .has anyone put braded lines on a street glibe with abs .
thanks
Old 02-02-2012, 11:13 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
There are two separate parts. You would need to buy the lower line (module to calipers) and an upper line (from master cylinder to module). To properly bleed them at install, you'll have to get a dealer to use the Digital Tech. to cycle the module to get air out of it. It's pretty much impossible to do at home. Non-ABS and it's much simpler.
BillinSC
03-26-2013 08:12 PM
Longhog
Wheels/Tires
05-04-2011 12:26 PM
Cousy
01-14-2011 07:46 AM
DocHarley
11-01-2010 12:15 AM
Duke of HD
05-14-2008 08:04 PM
Quick Reply: front brake lines 08 flhx abs
