Replacing brake lines
Old May 4, 2011 | 12:26 PM
Longhog's Avatar
Longhog
6th Gear
Default Replacing brake lines
I'm preparing to replace my 2010 FLHX (ABS) brake lines and I have a couple questions. The front brake lines run from the front fork to the ABS module. The lines are squeezed under the fuel tank along side the top frame tube. Do I need to drain and remove the fuel tank to get the old lines out and install the new lines? Also, the parts guy I talked to said that the computer needs to be reflashed at the dealer after replacing the brake lines to make the ABS work properly, is this true?
TUCCI
May 8, 2012 01:10 PM
Longhog
May 2, 2011 11:40 PM
Cousy
Jan 14, 2011 07:46 AM
kwb
Feb 28, 2009 07:45 AM
Duke of HD
May 14, 2008 08:04 PM
