Replacing upper brake line question?
Old May 8, 2012 | 12:03 PM
TUCCI's Avatar
TUCCI
Default Replacing upper brake line question?
Im going to be installing a 12" apes and thats going to make my brake line real tight. Im wanting to replace it with a cable from Magnum but Im not sure If I can replace just that line by itself, it almost looks like the whole assembly right down to the front calipers would have to be replaced. Has anyone replaced just the handlebar portion of the brake line by itself and how much longer than stock should I go for a 12" ape?
Old May 8, 2012 | 12:41 PM
TUCCI's Avatar
TUCCI
Bump,.......
Old May 8, 2012 | 12:53 PM
Buckinfitch's Avatar
Buckinfitch
Originally Posted by TUCCI
Bump,.......
go 6+ .. front ABS upper lines are 2 lines, you will need to remover the tank also (the connection is under it) and you need the other half to run to the ABS module behind
the throttle side rear panel, I just recently put Santee 11" mini-apes and with 6+ Magnum clutch and front brake lines that was more than enough.
https://www.hdforums.com/forum/touri...g-apechit.html
Old May 8, 2012 | 01:10 PM
TUCCI's Avatar
TUCCI
Buck I dont have ABS on this bike, managed to buy one before it was standard. Can I just replace the one line going down to the coupler or does the whole darn thing gotta be replaced it almost didnt look like it came loose off the coupler but then Ive never replaced a brake line before?
BooDaQ
Apr 21, 2018 08:44 AM
LA_Dog
Mar 25, 2015 01:39 AM
semifan1
Mar 7, 2014 11:23 PM
Cousy
Jan 14, 2011 07:46 AM
kwb
Feb 28, 2009 07:45 AM
