Kuryakyn Medallion Guage Kits
#31
RECENTLY INSTALLED
https://www.hdforums.com/forum/touri...pod-mount.html
#34
Yes I am very pleased with them so far. Went for a ride yesterday and they were easy to see and read in the bright sunlight. The oil temp guage seems be me a bit more accurate or sensitive. Must be due to the sensor sticking out in the oil pan further.
This is the HD sensor hidden in the adapter bolt:
This is the Medallion sensor next to the HD one. No adapter needed and the probe sticks out in the pan . Being more in the oil flow makes me believe this is why the reading are more sensitive to temp changes.
#36
My guess the stator & regulator was putting just enough current out for what I was using at the time. Then when I came to a quick stop it took a second or two to change or adjust the current flow for engine idle.
From what I understand the gauges except the oil temp gauge get all the information from the bikes ECM. I figured my battery or charging system might be getting weak so when I returned home I did check the battery voltage, load tested, and charging test and all checked out fine.
How often is your battery light coming on and staying on?
#37
well most of the time i'm at a long stop ligh or traffic backed up.i had it at the dealer and they replaced stator & regulator stiil wasn't fixed they change the rotor.went out for a ride this saturday and the light was back on,dealer mention maybe it's your gauges i think they were reaching for something to blame it on,i only have a 3rd brake light and i disconnected it and it still came on.
#38
#40
CNC WHEEL GUY
09-10-2006 11:20 PM
