Cam Install without Bearing Tools?
Old Mar 13, 2012 | 01:06 PM
Seener84's Avatar
Seener84
Default Cam Install without Bearing Tools?
I am installing cams in my 09 Street Glide and have read the service manual and the instructions that came with the cams but am not completely sure if I need to install new bearings and pull the old? I want to make sure I have everything that I need when I go to start the project next weekend so just need to be sure if I need to order bearings and tools now. Thanks for the help.
Old Mar 13, 2012 | 01:39 PM
myy2khog's Avatar
myy2khog
I'm just completing the same job on mine. I've got to adjust the valves yet. If you're going into it I would certainly change to the B-168 bearings. They're a much better bearing. They have a full complement of rollers instead of the gaged type. Get the Gary Beatty tool. Works great.
Old Mar 13, 2012 | 02:26 PM
mtclassic's Avatar
mtclassic
http://www.mbsmfg.com/hadatoac.html
fast shipping and excellent quality and won't find a better price. I ordered the remover and installer and it was on my door step in a couple of days. No offense to the Beatty set up, but this one is identical to my buddies factory harley install/removal tools. I was not comfortable tapping in the bearings but that is just my opinion.
Old Mar 13, 2012 | 02:34 PM
soft 02's Avatar
soft 02
If you dont have that many miles the stock bearings would be fine. The bearing issues were with the 88".
Old Mar 13, 2012 | 03:19 PM
2004Sierra's Avatar
2004Sierra
I used these same tools...Both the remover and installer worked great.
It almost took longer to open the box they were in than to remove and install the bearings.
I had thought about not replacing the bearings...But being I was in there anyway, why not do it just to be safe.
Old Mar 13, 2012 | 03:31 PM
mtclassic's Avatar
mtclassic
yes even the newer big bearings will benifit from the upgrade to the full cage 168's. I would change them even if the biker had no miles on it.
Old Mar 13, 2012 | 03:40 PM
fenderzig's Avatar
fenderzig
Change them while you're in there and post up a "wanted to buy" thread for some bearing puller/install tools. Every now and then guys will sell their tools after they've used them. I bought my tools off another forum member, used them, and then sold them to another member. He used them and I don't know where they went from there but you might be able to find a set that way. Fun job! Enjoy it!
Old Mar 13, 2012 | 04:07 PM
2black1s's Avatar
2black1s
I've only done one set of cams. I've never bought a special tool for anything unless there was absolutely no other way, including the inner cam bearings.
I removed my inner bearings with a tool I fashioned from a 3/8" bolt and a slide hammer. Worked perfectly. Cost = Free!
But if I were replacing cam bearings regularly, I'd buy a tool.
Old Mar 13, 2012 | 04:31 PM
Seener84's Avatar
Seener84
Thanks for the feedback. I ordered one from Beatty and will likely post it on the forum when I'm done.
Old Mar 13, 2012 | 04:51 PM
stupid_rope's Avatar
stupid_rope
replace them, its cheap. $20 for more efficient bearings
also, check out the Baisley oil spring. level 1 is 15% stronger than stock and it keeps your oil pressure up. Cost - $13 bucks.
Baisley
