Garmin USB Charging Cable
Old Mar 30, 2012 | 04:29 PM
ssmith579's Avatar
ssmith579
Default Garmin USB Charging Cable
Has anyone found a USB cable that will work as a charging cable for a Garmin Nuvi? A regular Type A to Mini USB cable makes the unit think it connected to a PC. I know a resistor between pins 4 and 5 on the mini USB side is whatthe unit is looking for but haven't a cable with that.
Old Mar 30, 2012 | 04:35 PM
larsfum's Avatar
larsfum
You need to have something that will step down the voltage to 5vdc. Google hard wire power Garmin.
Her's one:
http://www.amazon.com/Garmin-Hardwir.../dp/B001M09L20
and another:
http://www.sears.com/shc/s/p_10153_1...=SPM2791168901
One word of caution. I would silicone seal the module and also plug the usb end when not in use. a little water, and the thing is toast.
Old Mar 30, 2012 | 05:00 PM
ssmith579's Avatar
ssmith579
I already have a converter. I just want a cable with the resistor in it.
Old Mar 30, 2012 | 05:31 PM
K Melancon's Avatar
K Melancon
Yes if you look at the accessories. There is a combo cable set. It has a cable for the computer and a 110v AC cable. It plugs into the cradle just like the 12v DC cable and I purchase a Griffen cigerette charger with 2 USB ports. This Griffen also reduces power to 5 amps. When I plug in and turn the bars it does not hit the tank and all I have to do is pop the GPS out the cradle and store it when I stop some place.
Old Mar 30, 2012 | 07:27 PM
glide2005's Avatar
glide2005
I use the same cable for my Zumo 550 as I do for my Nuvi 550. Both use the regular usb on one end an a mini usb on the other. And yes it thinks it is hook up to a pc, but it still charges it. I do the same for my phone.
Old Mar 31, 2012 | 06:04 AM
dlongo8241's Avatar
dlongo8241
http://www.gpscity.com/3br-powerspor...18-inches.html
This is what I use on my zumo 220...14 bucks......
Old Mar 31, 2012 | 07:34 AM
santajim's Avatar
santajim
I got mine off of ebay hardwired it to the extra hot lead that goes tyo the headlight works great.
Old Mar 31, 2012 | 03:40 PM
DDuess's Avatar
DDuess
I got a newer Nuvi GPS and at the same time got the flush mount plug and a usb cable to neaten up the mess, and was frustrated by the computer mode jumping up each time power cycled on install or starting the bike, didn't realize the difference on the cable types. Cool info here. Going with the cable dlongo8241 suggested.
Old Apr 2, 2012 | 02:28 PM
leadermc's Avatar
leadermc
Former Sponsor
There are basic kits that wire to your battery, they have the voltage step-down in them, you can get them for USB (mini or micro): http://www.leadermotorcycle.com/CTGY/power.html
There's also no-wire USB chargers: http://www.leadermotorcycle.com/CTGY/SOLAR.html
Old Apr 2, 2012 | 03:05 PM
mglax13's Avatar
mglax13
There's a website that sells USB power plugs that I believe have waterproof boots on them, made for motorcycles, and they allow you to charge and use the nav without it thinking it's plugged into a PC. I have to look for the link, but it was mentioned in another thread on here where the OP uses it in conjunction with a Griffin USB/cigarette plug adapter.
