Exhaust torque spec 2011 FLHTK
Old 04-04-2012, 11:33 AM
wjl24's Avatar
wjl24
wjl24 is offline
Default Exhaust torque spec 2011 FLHTK
I'm replacing my head pipe with a Fuel Moto 2-1-2 and need the torque spec.
Also putting on air cleaner and Power Vision. Hoping to wake this thing up a little bit and cool it down as well.
I know....I need a service manual. Had one for the last bike. Haven't picked one up yet for this one.
Old 04-04-2012, 11:51 AM
fj1200's Avatar
fj1200
fj1200 is offline
You definitely need to follow the sequence of steps.
From the 2010 service manual:
After loosely installing header and installing the mufflers
1 tighten the bottom nut of the rear cylinder head flange to 9-18 inch-pounds
2 tighten top nut of rear cylinder to 100 - 120 inch-pounds
3 tighten the bottom nut to 100 - 120 inch-pounds
4 tighten the top nut of the front cylinder head flange to 9-18 inch-pounds
5 tighten the bottom nut of the front cylinder to 100 - 120 inch-pounds
6 tighten the top nut to 100 - 120 inch-pounds
then tighten the remaining fasteners
Old 04-04-2012, 02:50 PM
xdanman's Avatar
xdanman
xdanman is offline
Default re
Also retorque when hot. Well let them cool down enough not to burn your a--!
Old 04-04-2012, 02:55 PM
wjl24's Avatar
wjl24
wjl24 is offline
Thanks for your help guys.
Old 05-15-2012, 09:08 PM
StarwalkerP's Avatar
StarwalkerP
StarwalkerP is offline
I just purchased a 2010 flhtk. Has the Vance & Hines header pipes with Rinehart exhaust. I began hearing an exhaust leak & the front pipe at the head exhaust port had only one nut left holding the flange on & it was just about off. I needed this info on torque but i cant get off work early enough yo get new exhaust nuts at the HD desler here's my question. What type, grade, size & thread type do I look for at a good nuts&bolts store???
Thanks, David
Old 05-15-2012, 09:10 PM
StarwalkerP
Ok I hate to have to say this but I was referring to nuts. There !!!
BuzzL
06-20-2012 10:40 PM
racngrn
04-26-2012 12:11 AM
Guitar4Him
Exhaust System Topics
05-23-2011 08:16 PM
rhoppe
08-29-2008 10:51 AM
brandanfinn
07-22-2007 02:02 PM
Quick Reply: Exhaust torque spec 2011 FLHTK
