Primary Whining and now so am I
Old Aug 18, 2012 | 12:11 PM
  #31
96inchBOB's Avatar
96inchBOB
Default whinning
All you got to do is find that magic oil and it will fix anything wrong with a harley. I cant believe all the oil people has not figured out how to mix that chit up because you damn sure know harleys got it right.
Old Jul 9, 2022 | 10:10 PM
  #32
01 ultra JR's Avatar
01 ultra JR
Stage I
Originally Posted by drspencer
How do you loosen the chain/tensioner one click?
Thanks
remove the forward inspection window plate on the primary and you should be able to get to the lock nut that holds the tensioner. Loosen that slowly while maintaining pressure on the tensioner as to not let the tensioner drop multiple teeth at once. Carefully let the tensioner move one tooth and retighten to factory specified torque spec.
Old Jul 9, 2022 | 10:28 PM
  #33
GalvTexGuy's Avatar
GalvTexGuy
Thread is 10+ years old. I think he figured it out.
Old Jun 2, 2023 | 12:37 PM
  #34
Goobnjul's Avatar
Goobnjul
Stage I
Default Whining noise sounds like coming from stater side of engine
Exactly how do you loosen the tensioner by two teeth? Do you simply back of the adjuster screw?
Thanks
s
Big Dave
EVO
47
May 28, 2015 10:48 PM
CPL Haggard
Jul 1, 2012 10:56 PM
Ultradickweed
Mar 10, 2012 11:43 PM
IronmanSwamie
Jun 22, 2009 09:15 PM
Harley kevbro
Sep 13, 2007 06:56 AM
