6th gear indicator and cruise control link ?
Old 04-16-2012, 10:02 PM
steelerfan66's Avatar
steelerfan66
steelerfan66 is offline
6th Gear
Default 6th gear indicator and cruise control link ?
I have a 2010 Ultra Classic and on a recent trip I had a strange problem with the cruise control. While riding and cruise control set the cruise would just shut off ( green indication to red/orange ) and it would not activate. however, every time after a stop to refuel and back on the road it would work for a random amount of time and mileage. It ranged anywhere from 20 minutes to several hours. Another thing I noticed is that the the sixth gear indicator light on would also go out every time and not return until after a fuel stop. There appears to be a link but I, not sure if one is causing the other. While it was working I could set the cruise in other gears as long as I was going the minimum speed. Anyone have any thoughts ?
Old 04-16-2012, 10:22 PM
dwg1956's Avatar
dwg1956
dwg1956 is offline
Do you have a power commander v on your bike? If you do you need to hook a compter up to it and disable the diagnostics. Do a search on hd forums and there is a post explaining it. check this out
Does your bike have a PCV. If so there is a known firmware issue but also a workaround. You will need a laptop , power commander software from DynoJet's website, and USB cable to access the PCV. Perform the following:
1) In the Power Commander software go to Power Commander Tools/Configure/Harley ECM Data. Uncheck the box next to Diagnostic Port Enabled.
2) Click OK.
3) Click Send Map.
I had the same issue after installing a PCV during a stage 1 upgrade. This fixed my issue.
ut
Old 04-16-2012, 10:25 PM
steelerfan66
6th Gear
yes I have the PCV. I just saw the thread. I will give it a try. and post the results thanx dwg1956 !!
Old 04-16-2012, 10:35 PM
dwg1956's Avatar
dwg1956
dwg1956 is offline
It also makes the cruise stop working mine did it a few months ago and the pcv issue fixed the problem
bnkltah
09-21-2016 08:29 PM
CGP93
01-18-2014 08:31 PM
2 Evil
09-02-2013 12:49 PM
rhd01
07-05-2012 07:24 AM
Toe Knee
10-23-2011 05:42 PM
Quick Reply: 6th gear indicator and cruise control link ?
