Aftermarket LED Tour-pak lights?
Old Mar 10, 2013 | 02:35 PM
Deano13flhtk's Avatar
Deano13flhtk
Default Are you still loving the Custom Dynamics LED's ?
Originally Posted by Chunker
I replaced the stock incandescent tour-pak lights with the Custom Dynamics LED clusters along with the turn signals, RTB module and the connector that makes all the lights back there RTB. Very visible and stock appearance.
Did you get the LED's that are like a plate that you have to remove the lens to get them in? If so do you get much light on the sides, as they are a directional light, and are pointed to the rear?
I bought the Custom Dynamics LED's for my bullets, and absoloutley love them!
Old Mar 10, 2013 | 03:30 PM
sixty4nhalf's Avatar
sixty4nhalf
I just replaced the Stock red LED lens on mine with the Smoked LED lenses, I got mine through J&P Cycles. Only issue I had was that I had to switch out the wires, it was a quick and easy fix though. as far as price goes $102.99 but with gold club discount it was $92.96, but found a 15% discount which brought it to $87.55
Old Mar 10, 2013 | 04:03 PM
sixty4nhalf
There is no light that comes from the side of the tour-pak when the Custom Dynamic LED plates are used...
Old Mar 10, 2013 | 05:24 PM
littled62's Avatar
littled62
I put the Ride Time Technology progressive scan in mine last year and love it
http://www.ridetimetechnology.com
Old Mar 10, 2013 | 05:47 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
I have an 07 Ultra with every lens tinted. The side marker LED lights along the side of the tour-pak are now genuine HD because the aftermarket ones where losing LED bulbs at random and you can not open them up to fix them. (they lasted about two years before I had a problem) Corner marker lights/brake lights are tinted lenses. I bought LED boards from J&P because the 1157 LED bulbs are not bright enough in the day. The LED boards are crazy bright even brighter than the stock setup.
Old Oct 9, 2017 | 11:44 AM
Atlantaclassic's Avatar
Atlantaclassic
Default LED boards
what was the part number on the LED boards? I have a 07 also.
Old Oct 9, 2017 | 12:01 PM
groupw's Avatar
groupw
..... 4+ yr old thread
FuzzyD
General Topics/Tech Tips
May 16, 2014 08:04 PM
Ricketts
May 5, 2014 04:33 PM
HD Jake
Nov 8, 2013 08:20 PM
Mr. Wizard
Oct 9, 2009 03:48 PM
Lorenzo_82
Apr 14, 2009 01:06 PM
