96"SE255 beat by 103 stock engine
Old May 8, 2012 | 10:34 PM
iceman5218's Avatar
iceman5218
They changed the gearing in 5th and 6th gears in '09 to make 6th for usable at highway and not interstate.
Old May 8, 2012 | 10:35 PM
iclick's Avatar
iclick
I'm surprised. If it was a 60mph crack in 6th gear I might see this happening because of the gearing advantage of the '12 bike, but not anywhere else. I've ridden a stock '12 103 SG and there's no way that bike would pull my '07 SG with 96" with 255's and PV.
Old May 8, 2012 | 10:44 PM
silverado636's Avatar
silverado636
Unhappy
Originally Posted by iclick
This doesn't make sense. I've ridden a stock '12 103 SG and there's no way it'll pull my '07 SG with 96" with 255's and PV. What's already been said is true that the SG is lighter and the gearing is more favorable, but you should still be able to pull him most anywhere.
I have installed the 68t rear pulley. Forgot to mention that. Do I need a dyno tune?? I thought that Jamie should be able to get it very close. From all the reading I did on this forum I thought my combo of parts should have worked very well.
Old May 8, 2012 | 10:51 PM
ke5rbd's Avatar
ke5rbd
The 2007 has a 2.79 final gear ratio and the 2009 up has 2.87 ratio. The 07 had 66 rear sprocket and 12 has 68 tooth. The 103 has a .4 more compression ratio. Both weigh about the same. The stock cam has about the same torque and hp at the roll on rpm. Don't know how long you stayed in the throttle, but the 255 should have been stronger up at 90mph if it had had the same gear ratio. There is 7 cubic inch difference also. About the same as a 103 jumping on a 110. Guess who wins if everything else is equal.
Old May 8, 2012 | 11:00 PM
ThePointman's Avatar
ThePointman
It's actually very simple, SE255 cams make more mid range torque than horsepower.
Old May 8, 2012 | 11:04 PM
2black1s's Avatar
2black1s
How many trials did you guys run? Same result each time? Who hit the throttle first? That last question is the key - whoever hit the throttle first, even by just a fraction of a second, should pull away and continue to pull unless the latter is significantly faster.
Old May 8, 2012 | 11:08 PM
TheArchitect's Avatar
TheArchitect
Originally Posted by silverado636
My buddy has a new 2012 SG completely stock. We do a throttle roll on at 60 mph in 5th gear and he pulls away. My bike is a 07 EGC with Power Vision,SE255,V&H 2-1 propipe,stage 1 air cleaner and a tune from Jamie. Why would his bike be faster???? HELP.......................
Are you sure he was in 5th? If your buddies are like mine they'll tell you to do a 5th gear roll-on but they'll be in 4th or 3rd
Old May 8, 2012 | 11:12 PM
TheArchitect
OP did say that he's on an EGC while his buddy is on a SG, so he's carrying a bit of a weight penalty.
Old May 8, 2012 | 11:16 PM
silverado636
I have a 68t rear pulley...................... 2.79-2.87 is very close ratio. the 103 has stock cams, very lame if they are the same ones I removed from my bike this winter. They have no duration. I have to agree with iclick that his bike should not take mine. I'm contacting FuelMoto for help.
I was hoping their would have been something obvious I missed doing my upgrades.
Old May 8, 2012 | 11:34 PM
Shredding rubber's Avatar
Shredding rubber
It's all in the tune. Every motor although they are built on the same assembly line have slight and minute differences so a canned map will work great for most bikes but some need that bit of tweaking.
I'm a firm believer I'm getting an engine dyno tuned. The tuner can adjust so many variables and dial your bike in just right,accounting for subtle things,like elevation or more humid air.
You won't regret getting a dyno tune. My PVC had a generic map and my 106 made 95hp97tq.
I got it dyno tuned and it made 107hp115tq. And the dyno lines are so much different too. Instead of 2 really round type lines my tq curve was fairly flat hitting 100 at 2500rpm and staying over til 5300 rpm.
Hp was less of a mountain too,more like a hill.
What I'm saying is your tuner can adjust fuel and timing at every 50-100 rpms so those trims can be very finely tuned to get the very most out of your mods. Jmo
