Have a 09 Flhx with a 17-21 combo and abs , looking at 2012 Flhx non abs,will the wheel with abs bearings work on a non abs bike with correct spacers or is a bearing change required ?
Any Non-ABS wheel can be made into an ABS wheel by changing the non-ABS bearing to the ABS bearing. Then you just use the spacers that are on your ABS bike with the new wheels.
To use ABS wheels on a Non-ABS bike, you must change the bearings to Non-ABS bearings.
