Turn Signals
Trying to turn on the rear cylinder. I did not follow the proper procedures at first, ignition off, rolled off throttle & both signals flashed. Did I change/reset something else on the bike?
2012 Road Glide
2012 Road Glide
did you have the ignition on and then switch it off? sounds like the security setting.
also, what exactly are you trying to do? enable the eitms? there is a lot of confusion about this, all you as the operator can do is to enable/disable the eitms. the ecm will activate it only if certain parameters are met. you can not 'force' it to shut down the rear cylinder. there really is no reason to disable the eitms, it works pretty seamlessly.
Blitzkrick
Electrical/Lighting/Alarm
Aug 3, 2015 09:39 AM
landlord
May 9, 2006 03:01 AM
