I see a pair of Screaming Eagle true duals on craigslist for $375 The whole pipe, header and mufflers. They are coming off a 2003 Ultra, will they bolt on to my 06 Classic? Stock is just way to quiet, way to quiet...
Thanks
Steve in Ct
you could probably save $ and retain torque with a set of performance slip on mufflers using your stock headers
Mike
Thanks, i thought it was a good deal for the whole pipe set up, but dont want to loose any performance. I could buy them and sell the headers? but i'm not a big fan of the cross over on the stock set up. Haven't seen too many used slip ons and the new one are pretty $$$ depending on brand. I can't spend $500 on slip ons at this point.
Steve in Ct
I have an 08 system on my 1990 Glide. 08 is the latest that will retrofit, from what I can make out.
As for TDs and performance loss, I have used them on the same bike, followed by a 2-into-1 and had both set up by the same dyno shop. The TDs have a significantly lower torque curve in the low/mid range than the 2-into-1, also the 2-into-1 runs much smoother. So I get better performance and a much nicer ride with my 2-into-1. No going back to TDs for me!
