TW-222 cam?
Old Jul 25, 2012 | 12:37 AM
mgmmgm's Avatar
mgmmgm
Default TW-222 cam?
Anyone see this new cam grind? Fuelmoto has it coming for August.
Old Jul 25, 2012 | 02:07 AM
equandt's Avatar
equandt
Cut from the FM website....here it is....
**NEW** 7/24/2012 Fuel Moto is proud to announce a new cam we have been working on with Bobby Wood over the last 6 months called the Wood TW-222. This cam is designed specifically to optimize low RPM and midrange power on stock & lower compression 96" and 103" motors. This cam has .555 lift/short duration/early intake close, we have tested these cams in several motor-exhaust combinations and they make excellent low end torque and run out very smoothly. We have also posted dyno charts lower in this page
Part#
.053 Timing
Duration .053
Valve Lift
Lift TDC
Springs
Application
TW-222 14/34
34/14 228
228 .555
.555 .156
.156 Stock
**NEW** Low-End/midrange grind, designed for factory 96"& 103" motors. Works especially well in heavier bikes with lower compression
Old Jul 25, 2012 | 08:24 AM
mgmmgm's Avatar
mgmmgm
I was looking at the TW-555, or TMan 555 Torqster, but this TW-222 might be the ticket.
Old Jul 25, 2012 | 08:42 AM
iceman5218's Avatar
iceman5218
Site states the 103" gets 94/112 with full stage one and 95/112 with stage one and 2/1.
It didn't have a sheet showing what the 96" will do.
If the comparisons translate from the 555 then I would be upset with the 103" motor. There was only 4 hp diff from the 96" to the 103". Just some observations.
WG2011
Engine Mechanical Topics
166
Jun 4, 2018 09:47 PM
nevrenuf
Sep 30, 2014 02:39 PM
Ryan8585
Apr 23, 2013 12:54 PM
natural gasser
Exhaust System Topics
May 2, 2011 09:14 PM
Trek
15
Jan 27, 2011 11:58 PM
