Custom Dynamics LEDs ... Minor Issues
Old Oct 5, 2012 | 08:39 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Default Custom Dynamics LEDs ... Minor Issues
Got the front & rears installed today, just the LED set not the run/brake with controller set. Other than the lens being a @#$% to get snapped back on, very simple. But... a couple of small issues...
1- When turning on the blinker either L or R, I get a normal flash several times then it goes to fast flashing.
2- When I do the emergency flashers, it works fine but they wont shut off... turned ignition & motor off with no change. Ended up having to disconnect the battery to stop the flashing. Tried several times w/ same result.
I got these tru my local shop (discount) & the Drag Spec book calls these LEDs plug & play which in essence they are. The CD website says that if I have an alarm system, which I do, I might have to get a load equalizer... which I dont have.
I did call CD but the customer service line was already closed for the day.
So if you have any ideas on this, please chime in....
Old Oct 5, 2012 | 08:43 PM
MontyCop05's Avatar
MontyCop05
You can get away with installing them in just one end of the bike without a load equalizer but not both front and back. Simple answer: you need a load equalizer.
Old Oct 5, 2012 | 09:08 PM
Route66rider's Avatar
Route66rider
Yep, what MontyCop05 said. I went full LED on all lights on my '05. Headlight, taillight, turn signals and front driving light. A bit pricey, but I can see, and be seen. (I also added a set of hidden horns so I can be heard!)
wyotana
Jan 8, 2019 04:19 PM
badjujumatt
Milwaukee Eight (M8)
27
Oct 14, 2017 09:55 AM
sunstone53
Apr 20, 2014 09:24 AM
jam436
Nov 14, 2013 07:35 AM
SBJJC
Feb 24, 2010 07:09 PM
