where is the valve for the air shocks
Old Oct 7, 2012 | 09:55 AM
biil9's Avatar
biil9
Default where is the valve for the air shocks
on an 03 electra glide. want to add air for 2 up but cant find it
Old Oct 7, 2012 | 10:04 AM
rockajet1's Avatar
rockajet1
Default air shock valves
They are on the right rear fender strut. If its an Ultra you will have to take off the Tour Pak. Be careful because they only take 3-10 lbs of air. If you put a regular air compressor on them, you will blow the seals! You need a low pressure hand pump.
Old Oct 7, 2012 | 10:07 AM
Stiggy's Avatar
Stiggy
He means the right saddlebag, not the Tour Pak!
Old Oct 7, 2012 | 10:12 AM
DTTJGlide's Avatar
DTTJGlide
It's on the right side behind the saddlebag, you shouldn't have to do anything with the tourpack, but you will probably have to remove or at least tilt back the right saddlebag. The older shocks will take up to 30#, I think, it's been a while, but I know it's more than 10. You do need a hand pump with a gauge because they take a very low volume of air, a manual is your friend.
Old Oct 7, 2012 | 10:37 AM
Pumba11's Avatar
Pumba11
Run 25 lbs in my '99 for two up. Do not us a compressed air hose or even a standard bike pump you will easily blow out your shocks. Get the HD pump its made for it.
Old Oct 7, 2012 | 10:39 AM
stuart1270's Avatar
stuart1270
I found it on the other right. In other words it's on the left side not the right.
Old Oct 7, 2012 | 10:46 AM
jerryleon's Avatar
jerryleon
no owners manual huh ?
Old Oct 7, 2012 | 10:48 AM
Stiggy's Avatar
Stiggy
Not on an '03.
Old Oct 7, 2012 | 10:49 AM
twistedcherokee's Avatar
twistedcherokee
My 99 is on the right hand side.
Toby
Old Oct 7, 2012 | 10:51 AM
peddler's Avatar
peddler
On the 2007 there is one valve for the rear shocks on the left side (as you sit on the bike). If you open the saddlebag lid and tilt it back you can easily access the valve. On my '99 Ultra I believe there were 2 valves (front and back suspension) on the right side (as you sit on the bike). Same deal. Tilt the saddlebag lid back and access the valves. Don't know what year they were moved from the right to the left side.
NO COMPRESSORS!!!!!Very very small volume of low pressure air required.
