Speaker size?
5.25" stock but larger can fit.
J&M I believe has the largest fairing speaker @ 7.25" with their adapter rings.
Polk Audio MM651 6.5" are another good choice with adapter rings
The Polk Audio MM651 will also drop right into the rear speaker pods without modification, just drill new screw holes.
To change the rear requires a change in the entire speaker housing.
Polk Audio 6.5" speakers drop right into the 5.25" stock cutouts on the rear pods without modification.. you simply drill new screw holes
https://www.dropbox.com/s/9ft94vtk29...-45-00_109.jpg
