Who owns or has used this lift table ?
This BlackWidow lift table is onsale . http://www.discountramps.com/motorcycle-lift.htm
Who owns one or has used one ?
Tell us about it .
the add says :
Black Widow Premium Air Motorcycle Lift Product Features:
Tell us about it .
the add says :
- Motorcycle lift includes a 9" high oversize front tire clamp for extra security
- Air operated foot pedal allows a hands free operation without bending over
- Deluxe hydraulic ram will easily lift motorcycles up to 1000 lbs
- Includes 24" long removable rear loading ramp
- Front wheels makes it easy to roll lift around the shop
- Adjustable front support legs to keep lift from rolling with bike on it
- Rear drop out panel for service to rear tire, sprockets or drive shaft
- Multiple safety lock positions
- 11.5" x 21.75" rear tire drop panel is standard with all Black Widow motorcycle lift units
- Powder coated glossy black finish with built in checker diamond plate design for traction
- Optional 10" side extensions available for ATVs, lawn tractors, wide cycles, and 3 wheelers
- Optional 14" front extension available for choppers and longer motorcycles
- Include a wheel dolly to help move lift around the shop
- Great for service and storage of your motorcycle, garden tractor or ATV
- 11 gauge steel construction
- Requires 90-100 psi minimum air pressure & 120 psi maximum
- Heavy duty 2.4" x 1.2" x .125" thick scissor support arms
- Minimum 6.7 gallon / minute air compressor is recommended
- One year warranty
lift table
I bought the same table in October, under the name "Direct Lift",Procycle DT model. I also purchased the 2 ft extensions, for an overall width of 48". I can use it to service my 4 wheeler and also my lawnmower. I do like the lift. built well. easy to move around with included dolly. no more crawling around on the floor on my knees!!! Also works great as a portable work bench! One of my better purchases!!
