De-cat
Old Feb 1, 2013 | 03:03 PM
rellortnoc's Avatar
rellortnoc
Default De-cat
OK, I know several will disagree, but I just had my 2012 FLHTK de-catted and it sounds incredibly better. Stock mufflers! Really can hear the difference. Not that I'm planning on leaving it that way very long. I have SuperFlows coming in the mail. But I'm really impressed with the difference just de-catting makes!
Old Feb 1, 2013 | 04:07 PM
mathew2172's Avatar
mathew2172
I did it to mine with some S&S slip ons and a S&S air cleaner cover, the sound is great!
Old Feb 1, 2013 | 04:56 PM
Uncle Paul's Avatar
Uncle Paul
Now click on a set of vied's or tuner to make it run as good as it sounds : >)
Old Feb 1, 2013 | 05:29 PM
Buckeye1951's Avatar
Buckeye1951
+1 on de-catting, I did my 11 RKC before xmas, still waiting for a decent day to try it out. I added a new air cleaner and programmer from FuelMoto, the difference in sound (in the garage) is amazing.
Old Feb 1, 2013 | 05:44 PM
bgdv1's Avatar
bgdv1
had my 11 sg done. check my sig
Old Feb 1, 2013 | 08:23 PM
the warden's Avatar
the warden
Decatting the pipe, your ears and your right leg will thank you. Other than causing the EPA to scream, there is no downside.
Old Feb 2, 2013 | 03:06 PM
wjco9's Avatar
wjco9
Default Gut the cat
I agree, easy mod and great enhancement. I added V&H monster ovals and a K&N air filter and what a difference. If you're a little handy you can do it yourself. Here is some pics to help. Just remember to drill around the outside of the cat material before you knock it out makes it much easier. I used a screwdriver and hammer to finish up what little was left on the inside walls. Put 4 lines across the point ( front, both sides and back) where you cut it to line it up when you weld it back together.
Attached Thumbnails De-cat-2013-01-16_16-40-03_683.jpg   De-cat-2013-01-16_16-44-40_214.jpg   De-cat-2013-01-16_16-44-52_546.jpg   De-cat-2013-01-16_16-45-05_611.jpg
sloans4x4
Sep 18, 2015 05:27 PM
Blt93932@aol.com
Exhaust System Topics
Aug 6, 2013 08:45 PM
FORDTUFF
Jun 15, 2007 12:34 PM
Cage996
Apr 20, 2007 10:38 AM
In Memoriam Citoriplus
Nov 15, 2006 03:05 PM
