1997 Road King won't start
Old 04-14-2013, 05:05 PM
Rubenroadking's Avatar
Rubenroadking
Rubenroadking is offline
Stage IV
Update, i removed all the gas and removed the petcock. It does have a a vacuum line to the fuel valve. I checked the line from the tank to the fuel valve and if flows with no problem. I tried to blow air through the fuel valve but nothing flowed. Do I need vacuum applied to the valve before it will allow flow?
Old 04-14-2013, 05:29 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
yes, when assembled, vacuum from the intake opens the petcock ( if turned to "on" or "res") ......without vacuum applied there should be no flow at all.
there is another vacuum line to the VOES - a black plastic switch which retards the ignition timing when vacuum drops
Mike
blknslvr
05-16-2021 11:25 AM
Cameron Jones
02-19-2019 09:01 PM
Sean Ferg
08-07-2012 08:37 PM
wwalton259
04-24-2011 07:10 AM
jaycruiser
Exhaust System Topics
03-14-2009 09:10 AM
Quick Reply: 1997 Road King won't start
