hi .can some one direct me on some info..last fall i put krome swepper 2-2 and ad to extend tbw. change clutch cable.i remove the maxi-fuse only.when i put maxi-fuse back. heard.. small.. noise like. fuel pump. check battery .was low.charge-it good now . check all connector.and the switch on bar.still have no power.can be the green plug in bar.or have to unplug something else. no head light on bike and no passinglight plug-yet.yes did the search function . thank head mrfuji 2011 flhtc
