Pinging testing
Old May 18, 2013 | 11:30 PM
Uncle Chester's Avatar
Uncle Chester
Originally Posted by Matt0987
"And, if you just wish to TEST and look for ping and NOT fix it right away, borrow someones TTS, hook it up with a laptop, go ride and collect generic data."
TTS ???
TTS master tune, it's a flash tuner.
http://www.mastertune.net/
Old May 18, 2013 | 11:40 PM
DTTJGlide's Avatar
DTTJGlide
The problem is caused by a carbon build up on the pistons.
Old May 18, 2013 | 11:57 PM
Matt0987's Avatar
Matt0987
If this is the case, how do we clean it?
Old May 19, 2013 | 12:23 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Wild Card
I understand trying to find the cure. But I do not understand why it starts to happen in that range, more so milage.
yes mine has started to develop the same exact thing you describe...why now? what has changed?
This is not always the case, but more often than not it is because most air cleaners feed the hot dirty oily air from the engine back into the combustion chamber.
Not only does this compromise the performance of your bike (internal combustion engines run best with cool dry air mixed with gas and no oil), but the oil going into the combustion chamber builds up carbon deposits and effectively raise the compression ratio.
So now you have a bike that ran fine for thousands of miles, and then started pinging.
What do most people do? They treat the symptom instead of the cause. They retard the timing, thus reducing the performance of the bike even further.
What would be far better for engine longevity AND performance is to get an air cleaner, like an Outlaw 587, that does NOT feed that hot dirty oily air into the engine.
Once you do that, there are a few ways to get the carbon deposits out of your combustion chamber without pulling it apart.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 19, 2013 | 05:59 AM
Tn.Heritage's Avatar
Tn.Heritage
The cause apparently is carbon buildup due to dirty air I guess but if the motor company agrees that they need to add fuel then so can you. Personally I'd bite the bullet and find a reputable tuner in the area and get it fixed with the proper tune. If your still running stock then your running pretty lean from the get go. If that's not a route your willing to take hen maybe running some seafoam through your gas tank a couple of times might help s well. 1 other thing comes to mind is going to a colder plug such as the 10R12 from HD. This may help some but not sure, I run this year round but I don't ride in extreme cold either.
Old May 19, 2013 | 06:14 AM
golfblues's Avatar
golfblues
My 96 with woods 555's pinged badly in 5th and 6th when I opened the throttle. I took 4° of timing out of my tmax from 2800 up. Pinging is gone and she runs great.
Old May 19, 2013 | 06:43 AM
checkers's Avatar
checkers
DT Glide is likely correct. Carbon build up on pistons or combustion chamber will raise compression and thus a ping. Retarding timing to correct this will effect mpg and performance. Routing the crankcase breathers out of the combustion chamber may help, burning quality name brand fuel to incl pure gas will help, RPM's hot will help prevent/remove carbon build up, over fueling motor with "a tuner" will cause carbon build up. To eliminate this in automobile engines, the only product I have found over the years is Chevron Techron. Install 4-5 oz's to a full tank of fuel and run the motor to operating temp and ride it hard to high rpm's multiple times. Leave set overnight and do it again. May have to treat system several times. This stuff does work, and the injector version of this product works better then the fuel system cleaner version. No, I did not advise you to use Seafoam product, there is use for Seafoam, but it does not perform even close the the Techron.
Old May 19, 2013 | 06:51 AM
jus2anoyu's Avatar
jus2anoyu
The topic of venting the crankcase to the atmosphere is common. I did this to mine about a year ago, and have noticed great improvements. As someone else mentioned, your engine is not fond of burning moisture (a normal byproduct of an I. C. E.) and oil either.
Old May 19, 2013 | 07:44 AM
Pete6114's Avatar
Pete6114
Can you explain what you did?
Old May 19, 2013 | 08:14 AM
Pete6114's Avatar
Pete6114
Is the 4-5 ounces to a cars or bike's tank?
Never mind......
