shifting points
Old Jun 21, 2013 | 08:46 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by mikeo33y
thx for the info from the guys who sent info on a forum thats meant to give info. To those wise a####. F@#$ off. R u kidding. Why is there always a moron. Just asked a question. Been racing motorcycles since i was 10. Its a new bike that has a tendency to have issues with bearings and just wanted to know how and why some other riders with the same bike hit certain shift points. Its justa stinkin question and if u think its stupid then move on to another thread.
I think your retaliatory rant further perpetuates your lack of understanding how asking such a question as you did would leave yourself wide open for the type of comments that you received with regards to "shift points" ... Especially considering that you state that you have "Been racing motorcycles since i was 10" ... One would think that someone who is astute in the art of competitive motorcycling would have long ago figured out how to determine the optimal shift points to ensure deriving the best possible performance out of ones scooter ( Just my .02 cents worth .. actually with some of vocabulary that I used, maybe it was worth .05 cents ) Ride safe brother ... and ... Don't forget to shift and grow a thicker skin!
Old Jun 21, 2013 | 09:02 AM
Leftcoaster's Avatar
Leftcoaster
Like Uncle Larry said.
There ain't no rules or charts - you're riding a motorcycle, man. Once you've recognized the idle rpm and the rev limiter rpm, shifting anywhere in between becomes child's play - there's no right or wrong way. People that say they always shift between this rpm and that rpm are full of $hit - that just doesn't happen in the real world.
Your proclamation of vast motorcycling experience should have made this issue a no-brainer.
Old Jun 21, 2013 | 09:40 AM
my67pnycar's Avatar
my67pnycar
Is it winter again? This is sounding like one of those threads, lol.
Old Jun 21, 2013 | 09:49 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I have a Blackline and at normal speeds, I shift about at 2400rpm, when I've looked. And in tiwn, I cruise at 2000 in gears up to 4th.
Old Jun 21, 2013 | 10:55 AM
Harleypingman's Avatar
Harleypingman
Just stepped up from a fat bob to a Ultra. What are your shifting points on the ultra? I seem to be shifting at a lower rpm with the ultra. At first i figured id have to rev alittle higher due to the extra 200 lbs but shifting at around 2500 rpm seems right. anything higher the bike seems to over rev and hit a limiter. any imut would help much. thx.
Not sure what you mean when you say "over rev" or "limiter.". There is an rpm limiter at 5200 IIRC.
Also, if you are entering an interstate that has even moderate traffic, you would be wise to run at a pretty high rpm before shifting and reaching cruising speed. Likewise, if you ride twistys even with moderate enthusiasm, you will want to keep rpms up and use engine braking.
You will be a safer rider if you are keeping your head up and not looking down at the tach.
Carl
Old Jun 21, 2013 | 11:35 AM
BigDave75's Avatar
BigDave75
Right at or above 3000 for me.
Old Jun 21, 2013 | 12:21 PM
Trial dog's Avatar
Trial dog
The answer to the question: "It depends"
Many above have mentioned some of the things it depends on. If you are hitting the rev limiter slightly above 2500 then maybe your tach is out of whack.
Old Jun 21, 2013 | 01:10 PM
Twistnride's Avatar
Twistnride
Racing since you were 10? Musta' been all gangsta' on yer Big Wheel,making those "Vrooom! Vrooom!" noises. What a tool. Guess all them "racing" bikes had automatic trannies,so you never had to worry about keeping the motor in the optimum power range. Or you lost every race.
Old Jun 21, 2013 | 01:30 PM
UUNetBill's Avatar
UUNetBill
Rode a RK without a tach, didn't miss it. Bought a SG with a tach, don't often use it. It's been my experience that the bike tells you when to shift - there's no 'right' or 'wrong' shift point (unless you're lugging or bouncing off the limiter).
The scientific answer is "For power, shift at or just past your maximum power output. For economy, shift points are less important than throttle opening." Or some crap like that.
The real-world answer is "Just ride it, you'll know."
Old Jun 22, 2013 | 05:22 PM
twistedcherokee's Avatar
twistedcherokee
You may want to clarify the anything over 2500 feels like it is hitting a rev limiter. If you have raced bikes then you should know if the bike is running right. The engine should twist up to 5K with no problems, if it doesn't you may have other problems. Good luck
Toby
